It is currently Fri Jul 18, 2025 5:08 am
 Post subject: End pin
PostPosted: Thu Mar 12, 2015 9:09 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I am restoring a 1933 L-00 and just got it back from the painter (black finish). This is turning out way better than I ever could have hoped for.
I bought a set of Antique Acoustics Gibson reproduction bridge pins and end pin. They are very nice. They cost $26 with shipping and I only paid $41 for the guitar!
No problems with the bridge pins, but the end pin is too small for the existing hole. Is there a good way to reduce the size of the hole in the guitar?
Thanks in advance
Ed
 Post subject: Re: End pin
PostPosted: Thu Mar 12, 2015 10:20 pm
If it's just slightly undersized you can glue a plane shaving or two to the diameter.
PostPosted: Fri Mar 13, 2015 11:40 pm
First name: Allan
Last Name: Bacon
^^^^ And a little sanding should do the trick. Or if you have access to a lathe, you could ream a plug the diameter of the pin. Glue it to the pin, and then turn it down to match.
PostPosted: Sun Mar 15, 2015 8:14 am
Last Name: Minch
City: Chestertown
Thanks.
I might stick with Plan A and glue a nicely fitted plug into the hole and drill and ream it.
Ed
PostPosted: Sun Mar 15, 2015 9:23 am
Ruby50 wrote:
Thanks.
Ed
That's what I would do, turn a plug, install, ream, fit, call if good.
Can't wait to see the L-OO Ed!!!
